Instance Transforms
igalz1
, Dec 22 2004 17:52
11 replies to this topic
Posted 22 December 2004 - 17:52
I am trying using Instance Transforms with msi 3.0 on winXP
as described in the latest SDK it doesn't work.
Please help me
Please help me
Posted 23 December 2004 - 10:15
How does it fail (symptoms, error messages)?
Did you validate your .msi file?
What are the exact steps you did?
Posted 23 December 2004 - 10:17
Also you need to be on XP SP1 or higher. In XP RTM this won't work.
Posted 23 December 2004 - 21:40
Hello Stefan,
What I did is this.
I have a product
1. I created copy of this product
2. I modify ProductCode property Property table guid (change one number there).
3 I modify ProductName in the Property table
4 Created InstanceID in Property table set it to 1
5.Generate transform file from the copy and
msiexec /i mypackage.msi TRANSFORMS=instance.mst MSINEWINSTANCE=1
What I did is this.
I have a product
Posted 04 January 2005 - 15:23
Hi ,
I did this but it didn't work.
Do you know please what the problem?
Posted 10 January 2005 - 10:29
Repeating my question: are you trying this on XP RTM or on XP Sp1 or higher?
Posted 14 January 2005 - 23:12
Hi I am sorry again but I am doing something wrong over here could someone tell me if he/she has some experience with Installing Multiple Instance
Posted 19 January 2005 - 16:52
I use instance transform and that work very well.
Maybe you have to put your value for Product Code, Product Name and Package code in the table ISProductConfigurationInstance.
Posted 19 January 2005 - 18:35
Hi laurent,
Thank you, Could you please tell me the step that you did to make it works
Thanks.
Thanks.
