I have migrated my IS 12 project to IS 2009. I have created a setup with the migrated project. I haven't done any changes in the ISM file (after upgradation to IS 2009) . While installing the setup Iam getting error as:
Error 1334.The file ‘newGen.gif' cannot be installed because the file cannot be found in cabinet file 'Data1.cab'. This could indicate a network error, an error reading from the CD-ROM, or a problem with this package.
But the gif file is located in the cabinet file.....
I found out that in IS 12 ism file, the image file name looks like "newGen.gif" - Actuall file contains exactly the same name (some are capital and some are small). After converting IS 12 ISM to IS 2009 ISM file, all the image file name in ISM are saving as small letters only - something like "newgen.gif". This causes the problem.
Can any body help me out in why IS 2009 is saving file names as small letters only.... (I have saved ISM in XML format. after that opened the file in a notepad and traced out the changes).
Can anybody help me in resolving this issue. .................
Thanks in advance ...
Edited by vPanchumarthi, 08 July 2009 - 05:11.
