Your immediate assistance is appreciated.
Pam
Posted 26 February 2001 - 18:30
Pam
Posted 27 February 2001 - 16:39
In general, installing Windows Installer on WinNT systems does not seem to require a reboot simply from running InstMsi.exe (the redistributable from the SDK). I can't say too much about the Win 9x install, since we don't use it in our install base.
About all I can recommend, if you have source code for your wrapper application, is that you take a look at the launching application and see what is causing the reboot. Then you can insert a dialog in the wrapper sequence.
If the reboot is being generated *within* an MSI package, then the reason it does not deploy a prompt may be that the REBOOTPROMPT Property is set to Suppress (or just "s"). That will effect any reboot without prompting the user in any way.
Hope that helps.
