Hello Dimitri,
I'm not sure if this solution will work for you, but give it a try. I have two VBScript CA's. One adds shortcuts, the other (on an uninstall) goes thru and removes any. Here is the VBScript code for adding the shortcuts.... try replacing a few of the lines appropriate to your install and then call the CA at the end of the install (hooked to the Finish button).
On error resume next
'Setup some defaults
Set WshShell = CreateObject ("WScript.Shell")
Set WshEnvironment = WshShell.Environment("process")
Set fsoLog = CreateObject("Scripting.FileSystemObject")
'Get the temp directory & start the log
strTempDir = WshEnvironment("TEMP")
Set logFile = fsoLog.CreateTextFile ( strTempDir & "\AddDesktopShortcut.txt", TRUE)
bError = False
logFile.WriteLine "Log Started: " & now
logFile.WriteLine "Install File"
strLink = WshShell.SpecialFolders("Desktop") & "\LinkName.lnk"
logFile.WriteLine strLink
strPath = WshShell.RegRead("HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\App Paths\EXENAME.exe\Path")
if strPath = "" then
logFile.WriteLine "Error locating registry entry for EXENAME.exe"
bError = True
end if
logFile.WriteLine strPath
if Right(strPath, 1) = "\" then
strExePath = strPath & "EXENAME.exe"
else
strExePath = strPath & "\EXENAME.exe"
end if
logFile.WriteLine strExePath
if not bError then
set WshShortCut = WshShell.CreateShortcut(strLink)
WshShortCut.Description = "Description of your shortcut"
WshShortCut.IconLocation = strExePath & ", 0"
WshShortCut.TargetPath = strExePath
WshShortCut.WorkingDirectory = strPath
WshShortCut.WindowStyle = 1
WshShortCut.Save
end if
Hope this helps, Bri
