Scenario:
Installscript
1. build installscript project
2. install the newly build project
3. then rebuild the project
4. install the newly build project (it opens the maintenance dialog)
Basic MSI
4. install the newly build project (it has an error, the error message is another version is running)
how can i make the basic msi same behavior as in the installscript, i want that even i have a new build and there is an existing installed same product on my machine it will open the maintenance dialog.
hope you can help me with this, if my question is unclear just tell me i will rephrse it. thank you very much
installation problem
haroldxious
, May 12 2007 01:18
Posted 16 May 2007 - 21:52
You *could* do this by disabling the automatic PackageCode generation. But you *should not* do this, as this can cause all sorts of errors, and it violates the MSI rules. What are you trying to do? Test the update install? Or test the new version without having to manually uninstall the existing version? I the first case: create a Minor or Major Upgrade, depending on your requirements. USe the Update settings view for this. In the latter case, there's an option in the IDE that lets you automatically uninstall the old version when you launch the new version.
