During a basic installation, I have a custom action based on a C/C++ DLL function. Within the CA, how can I determine what type of install is being performed? (eg, Install, Modify, Repair, Uninstall)
A code sample would be greatly appreciated.
Regards,
Sijmen.
Install Type during Basic install CA
sijmen
, Nov 26 2002 07:50
Posted 26 November 2002 - 15:56
one method is to use the MSIGetMode function. this fn. will return a boolean response based upon the specified run mode.
it takes two parameters, the current installer handle and the run mode to check. if you want to check for a maintenance re-install/reconfig the run mode would be "MSIRUNMODE_MAINTENANCE". when queried the fn. would return true if a maintenance install is occurring...
depending on the requirement this might satisfty your needs ?
full details can be found in the Windows Installer - Platform SDK, search for MSIGetMode...
