I have no clue, why UnInstall does not remove some of my files.
The setup is developed with ISDEV7. Operatingsystem for the test is WinXP SP1a. The testcase is
- install on a "clean" machine - I am using VMWARE
- invoke the application and then close it immediately (I just now tested, that this has no effect on the case - the problem is the same if I do not invoke the app.)
- uninstall the software
This results in following previously installed files being left on the system:
- one dll
- fore typelibraries
I have performed the installation and the uninstallation with verbose logging but I cannot see anything unnormal.
I planned to attach the verbose log to this message, but it exceeds 100k even if ZIP'ed
Together with the logfile I will provide the filenames of the not removed files in order to help analyzing the issue.
Best regards,
Jo Fischer
Edited by fischerlinden, 13 January 2004 - 17:24.
