I created a merge module that is included in two MSIs. The question is, how can I ensure that some custom actions in my merge module only take place when the files in the merge module are first installed? And how can I make other custom actions that are only run when the files are finally removed?
I thought this would be done using conditions such as
?Component1=2 (TRUE if Component1 has not been installed)
$Component2=2 (TRUE if Component2 will be removed)
[This is slight simplification of what I am doing]
However, I install one product containing the merge module and this is fine. Then I install the second product, and the log tells me that all components are Absent, when I would expect MSI to find that the components are installed.
Can anyone explain this and suggest an alternative method? Thanks.
Conditions for custom actions
catrill
, Jun 24 2004 15:44
Posted 25 June 2004 - 01:11
Have a look at using the
ModuleInstallExecuteSequence and ModuleAdminExecuteSequence
This allows you to place the custom action after something like Install Files, or even install finalize.
Posted 25 June 2004 - 09:07
I think that these component install states indicate whether this component will be installed by this product. The actual install action will be increasing/decreasing a reference count, of course.
As a workaround, use AppSearch and search for a component (CompLocator).
Posted 25 June 2004 - 12:50
I found this post on the installshield forum from RRanck (thanks RRanck):
To detect when the component is being installed: $ComponentName=3
To detect when the component is being removed:
$ComponentName=2
The $ gives you the action state of the component, while the ? gives the current state. When installing the second product, if the component has already been installed with the first product, $ComponentName will evaluate to -1. Like wise, when uninstalling products, $ComponentName will remain -1 until the last product to be uninstalled actually removes the component.
For me, the detection of component removal using $ComponentName=2 works, but detection of the first install using $ComponentName=3 doesn't work. Also the detection of the current install state (?ComponentName) does not give me 'Installed Local' when I expect it (after I have installed the first product containing the component).
I have worked around using AppSearch to check whether a registry entry is present.
$ComponentName=2
