My test team has done it again. Once the app is installed, they access the Maintenance page. Then select "modify" and uncheck all components and complete the maintenance. Now a bug is logged that after you do this, and try to start the program, they get an error message, the app can't run!!!! Surprise!
Has anyone run into this situation? I've thought of several options, like disabling the "Next" button if all components are unchecked, or not allowing them to uncheck all boxes. I thought I'd check to see if someone else has tackled this problem before and if so, any suggestions?
Becky
