When I first started work on my Installsheild project, I compiled with a DEMO_RELEASE flag, this was released with no problems
We then needed to roll out a bigger version with a FULL_RELEASE flag. They need to act like seperate products, so you could have the demo and the full installer on the same machine at the same time
When I first started running the FULL_RELEASE build, it would always ask me to remove, repair or modify so I changed the GUID of the project
However, when I try to install the FULL_RELEASE one it gives me a 2711 error. So then I realised perhaps I needed to updated the GUID of each component.
I did this, but still it gives me the error just after I tell it what type of install I want (typical, custom, minimal)
Any ideas how to get round this?
Errors using same project
doubli
, Feb 26 2003 20:21
Posted 26 February 2003 - 20:23
This error only appears when the DEMO version is installed on the same machine. If I take that off and run the FULL one it works fine. It appears there is a conflict?
Posted 27 February 2003 - 09:50
First, you must always change the PackageCode - to avoid misleading error messages.
If you want to install both versions side by side, they must have different ProductCodes.
