RemoveExistingProducts
Posted 13 August 2001 - 15:54
Is it possible to avoid WindowsInstaller to launch this reboot?
Help!!
Posted 13 August 2001 - 16:26
What is your custom action trying to do?
RemoveExisitingProducts uses your execute sequence from the old version to remove obsoleted components. So it is your code that is requesting the reboot.
Posted 14 August 2001 - 07:45
In fact, in my soft, I have many CA that set manythings and any other CA that are launch only when removing that reset these manythings. So after an upgrade, if I don't put CA after RemoveExistingProducts, my Things are not set anymore!
Any idea?
Posted 14 August 2001 - 10:01
1. Actions default and custom that prepare the installer environment
2. InstallInitialize
3. Actions default and deferred/commit/rollback custom that modify system
4. InstallFinalize
5. RemoveExistingProducts
In this scheme an upgrade install, Installs/Overwrites the new stuff then removes components no longer needed. This can be a problem when the old install is buggy.
There should not be any action other than RemoveExistingProducts after InstallFinalize.
Ok. I accept you have improper installations out in the field (I did when I started out).
ScheduleReboot only sets a flag. The reboot prompt is the last action the install engine performs. That is after the new install action and the remove actions have been installed. So if your custom action is being cut off it is because you have not told the installer to wait for it to complete. If you set the flags of the CA so the installer waits the CA will complete before the reboot prompt appears.
