We want to update the xml file by comparing each other.
Suppose I have a.xml file with following info:
<servlet-mapping>
<servlet-name>abc</servlet-name>
<url-pattern>/servlet/abc</url-pattern>
</servlet-mapping> & likewise many other tags.
b.xml file with
<servlet-mapping>
<servlet-name>xyz</servlet-name>
<url-pattern>/servlet/xyz</url-pattern>
</servlet-mapping>
But the information will be much more different in actual scenario.
So basically we need soe mechanism that allows us to compare 2 files & update 1 of the file wit the required information.
Kindly help.....
Thanks in advance
File compare & Update
mankul22
, Mar 24 2005 12:37
Posted 26 March 2005 - 09:18
Does the XML Modification view in INstallShield 10.5 help?
Otherwise you would have to write your own script code to compare and merge/update the files.
