Hello,
I read much topics about similar problems but I really didt understand the solutions. I have follwoing problem:
I have different Features in my installer, one Feature is called dotNET. If the user selects the dotNET Feature I need to run some CustomActions to register VSIP things. Like run an HelpReg.exe or to run devenv /setup. Everything works fine if I do not query the conditions on the CustomActions. But now I want to make that everything wil lwork ok. I insert the CustomAction after "SelfRegModules" and I put the conditions:
&dotNET=3 AND DEVENV<>""
to this actions. But no action will run. If I remove the &dotNET=3 it work.
Is there a trick to find out if an feature was installed local?
Ingo
Check if Feature is installed
Ocrana
, Oct 25 2005 00:33
