We are using a uninstall short cut for our product under the path Start->All Programs->Our Product. After installing the product i am trying to uninstall the product using this shortcut but i am getting an error which says "This action is only valid for products that are currently installed"... The uninstallation works fine if i do it from control panel, but from the shortcut i am facing a problem. Please suggest how to rectify this.
Regards,
Balaji
Error while trying to uninstall the product..
balaji4u
, Jan 02 2013 07:25
Posted 03 January 2013 - 17:05
How do you create that uninstall shortcut, what's its command line?
Posted 08 January 2013 - 06:09
Hi ,
I was able to resolve this , we had changed our product code and the command line parameters for this shortcut was using the earlier product code and i changed it to current one and it starts working. Thanks for your response.
Posted 08 January 2013 - 12:08
You can user [ProductCode] in the command line, so it will always use the correct one.
