I am using appsearch to populate CURRENTDEVICEPATH with HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\DevicePath
The value "C:\Drivers\dj450.prn" is then appended to registry value if it does not exist using following condition on component registry1:
Settings for Component Registry1:
Shared: No
Condition: NOT ( (CURRENTDEVICEPATH~><";C:\Drivers\dj450.prn\") OR (CURRENTDEVICEPATH~><";C:\Drivers\dj450.prn") )
Permanent: Yes
Reevaluate Condition: Yes
Never Overwrite: No
The above condition is not evaluated during a repair and keeps appending "C:\Drivers\dj450.prn" to DevicePath value.
If is I set the Reevaluate Condition to Yes to make it a transitive component the condition is evaluated and the following happens:
If "C:\Drivers\dj450.prn" does not exist in the devicepath it is added..
Component Condition not Evaluated during Repair
Tone
, Nov 17 2005 23:44
Posted 17 November 2005 - 23:44
| MSI (s) (F4:FC) [20:42:28:375]: Feature: HP_DJ450; Installed: Local; Request: Reinstall; Action: Reinstall MSI (s) (F4:FC) [20:42:28:375]: [B]Component: registry1; Installed: Local; Request: Local; Action: Local[/B] MSI (s) (F4:FC) [20:42:28:375]: Component: HPWDRPP0.DL_; Installed: Local; Request: Local; Action: Local MSI (s) (F4:FC) [20:42:28:375]: Component: __registry165; Installed: Null; Request: Local; Action: Local |
If "C:\Drivers\dj450.prn" does exist in the devicepath then the component is uninstalled and value deleted..
| MSI (s) (A4:C0) [22:21:36:859]: Feature: HP_DJ450; Installed: Local; Request: Reinstall; Action: Reinstall MSI (s) (A4:C0) [22:21:36:859]: [B]Component: registry1; Installed: Local; Request: Local; Action: Absent[/B] MSI (s) (A4:C0) [22:21:36:859]: Component: HPWDRPP0.DL_; Installed: Local; Request: Local; Action: Local MSI (s) (A4:C0) [22:21:36:859]: Component: __registry165; Installed: Null; Request: Local; Action: Absent |
Is there anyway of the condition being false and the component not being removed during repair..?
(MSI is called from command line with the /passive switch)
Thanks..
Posted 17 November 2005 - 23:55
I have delivered the drivers using printui.dll, would like to use this for other packages if its possible..
Thanks..
Thanks..
