Hello,
I try do make a setup for a network application. This setup need to create a shortcut base on the application path. The correct value of working directory is necessary to work properly.
So I try to fill this field "Working directory" with the network letter. Is there a way !
SourceDir is not reconize in this field.
Shortcut base on SourceDir
kbenn
, Jan 26 2005 10:54
Posted 27 January 2005 - 11:50
If the exe installs to INSTALLDIR then you should enter INSTALLDIR as the wroking directory.
