hello!
what can i do if i want the installdir depending on a registry entry. the default installpath shoud be read from the registry.
thanks,
Quentin Denis
INSTALLDIR from registry
denisq
, Jan 24 2003 11:20
Posted 24 January 2003 - 22:08
This is fairly easy - You can do this with a custom action: grab the value from the registry in installscript RegGetDBRegistryValue or some similar function and store the value in the INSTALLDIR property using MSiSetProperty.
Posted 21 April 2003 - 19:58
| QUOTE (denisq @ 2003-01-25 10:27) |
| and if i want the setup to quit if the entry is not present? |
Easy - if you create a Property value called "IsRegPresent" and assign it a 0 - if not present. and 1 - if it is present within the custom action that you wrote.
now that the property is set, you can check for this property in the install sequence. if 0, then quit.
Posted 25 April 2003 - 09:44
How do you get the value of the INSTALLDIR into the vbscript portion of a custom action ?
is it a normal property ?
Posted 27 April 2003 - 18:58
snippet :
Dim myProp
myProp = session.Property("INSTALLDIR")
Dim myProp
Rajiv Madassery
Galway Scripting Center
Digital GlobalSoft Ltd.
(Subsidiary of Hewlett-Packard Company)
