I have a install kit created with IS 2.03, and the following problem: when uninstalling from the original setup.exe file (Start installer and select Remove) all files are removed BUT when uninstalling from Add/Remove all the files that are removed through script or through calls to dll or exe files are left behind. All the exe/dll file that I use are also installed during the install procedure.
Anyone any idea, PLEASE?
Florin
