(I am talking about a "legal" way of doing it. I assume you can hack this by replacing the file in the dllcache folder as well as in the system folder with a custom action, but anoyone doing this should be shot
System File Protection
Glytzhkof
, Jul 24 2004 06:25
Posted 24 July 2004 - 06:25
It is not entirely clear to me how SFP really works. I installed Kodak EasyShare the other day, and it is clear that it has replaced some system files. The question is how did it succeed doing this? I was under the impression that the only way to update these files was using Microsoft's service pack installations or hotfixes. I assume this means that the Kodak setup then have silently installed some hotfix from Microsoft during the main setup installation? Am I correct in this assumption, or is there some poorly documented way to make windows installer replace a system file and have the change persist?
Posted 24 July 2004 - 13:11
Which file has been updated? On which operating system? I installed Kodak EasyShare a few weeks ago on XP and I'd like to check.
Posted 25 July 2004 - 04:20
I didn't extract a list of the files replaced, but what happened was that I was monitoring the setup using Unicenter repackager. After I was done capturing the system changes I was notified that "...the system is permanently changed, windows protected files have been updated and the reference system cannot be reset". I will see if I can get a list of the files replaced.
And the system I installed on was XP, SP1.
Edited by Glytzhkof, 25 July 2004 - 04:21.
Posted 28 July 2004 - 11:44
| If a program uses a different method to replace protected files, WFP restores the original files. The Windows Installer adheres to WFP when installing critical system files and calls WFP with a request to install or replace the protected file instead of trying to install or replace a protected file itself. |
Posted 29 July 2004 - 01:40
Hi Petch, yes I have read that section a number of times
. The problem is that the MSI setup DID replace system files, regardless of the fact that it is supposed to obey this rule. I am wondering how this happened, and the only thing I can think of is a silent install of a Microsoft hotfix.
