We are using Install Shield 10.0 (Install Script). We do not want to show option Repair, Modify. Only need to show Uninstall/Remove option. How should I do it?
Rahul
Removing Modify, repair options
rahuld
, May 03 2005 18:07
Posted 03 May 2005 - 18:11
Just turn it off in your IDE in "Genereal Information"->"Add/Remove programs" there are some x like ...
"Disable Change Button"
Bonum initium est dimidium facti
Posted 03 May 2005 - 18:26
Ok I set Disable Change Button to Yes but still it shows the other two options.
Do it has to any connection with "Maintianance Experince" and "Update Mode Support" options from Genereal Information --> Project Properties.
What should this options set to?
I have return a code which will create an Uninstaller for my product and put the
Uninstaller in Windows --> Programs --> Comp Name --> Unistaller. Now when I run the Uninstaller the code for uninstaller do not gets executed. I put the code for uninstaller in OnMaintUIAfter().
Am I doing something wrong here.
Please suggest.
-- Rahul
Please suggest.
-- Rahul
Posted 03 May 2005 - 18:38
if radically then something like this ...
szKey="Software\\Microsoft\\Windows\\CurrentVersion\\Uninstall\\" + PRODUCT_GUID; RegDBSetDefaultRoot(HKEY_LOCAL_MACHINE); RegDBSetKeyValueEx( szKey, "NoRemove", REGDB_DWORD, "1",-1); RegDBSetKeyValueEx( szKey, "NoModify", REGDB_DWORD, "1",-1); RegDBSetKeyValueEx( szKey, "NoRepair", REGDB_DWORD, "1",-1); |
Or try to write not "1" but "0"
Posted 24 May 2005 - 11:14
I have a similar problem. I set the 3 registry entries and it works as expected in win 2000 and XP (as also explained in IS X help file).
Unfortunately, in win 9x, me and NT the 3 entries in registry are not read, so I can uninstall my application form add/remove in control panel....
How can I disable or simply delete it from the list?
Thanks.
Thanks.
