How to make installer support all users
HermioneJJ
, Mar 29 2006 14:05
Posted 29 March 2006 - 14:05
I have created a basic msi project, it has some merge models, it has some registry keys under current user. but not support multi users, can you give me some good ideas? thank you
Posted 30 March 2006 - 09:24
| but not support multi users |
I don't understand your question. Are you installing this package per-user or per-machine (ALLUSERS=1)?
Posted 30 March 2006 - 09:59
I want to install per-machine
I used (ALLUSERS=1), when installing program, it will create a registry key under HKEY_CURRENT_USER\Software\MyProject\MyKey, and it has some registry information. It is ok for current user.
But if others user login it, the registry key does not exist under HKEY_CURRENT_USER, but another application needs to read registry information from there, so it could not support multi user to use it.
PS MyKey must be written to HKEY_CURRENT_USER, not HKEY_LOCAL_MACHINE. Could you give me some solution or direction about it?
Thank you so much
Erin
Thank you so much
Erin
Posted 30 March 2006 - 10:25
This article might help you:
How do I add HKEY_CURRENT_USER registry entries to all profiles?
http://www.msifaq.com/a/1011.htm
