Anyone see the same problem? Thanks.
Advise problem with Developer 7.0.2?
jyx2003
, Jan 21 2003 17:34
Posted 21 January 2003 - 17:34
Install the software with all options and then on first launch of the main executable for the product, the 'configure' (msiexec.exe) comes up for about 10-15 minutes before it allows the product to launch. Second time launch is fine. The installer has all features or shortcuts set as "disallow advertise".
Posted 29 January 2003 - 11:03
Is it possible that MSI 2.0 is installed at the first launch ?
Barbara
Barbara
The difference between theory and practice is larger in practice than in the theory.
Posted 29 January 2003 - 16:36
just to expand on what was in previous post...
check the version of the msi engine prior to install and check to make sure the minimum required engine ( from the msi summary stream of the msi ) matches... if not then a v1.0/v1.2 will be replaced by a v1.5 or v2.0 ( or even v2.0.2600.2 ) requirement...
another possibility is that the installed msi has component conflicts with another msi on the system... msispy and windiff will allow you to check this fairly quickly...
