How is it possible to detect that a reboot is required at the end of the UI-Sequence (in the SetupCompleteSuccess dialog)? The property "ReplacedInUseFiles" is set during the Execute sequence, but it's value is not returned to the UI-sequence.
As a workaround, I tried to set a global property "REBOOTREQUIRED" depending on the state of "ReplacedInUseFiles" after "InstallFinalize" in the Execute sequence and use this global one in the UI sequence - but that doesn't help, no property is returned from Execute to UI sequence.
Thanks in advance.
How to detect reboot in UI Sequence
hteichert
, Feb 06 2004 10:14
Posted 06 February 2004 - 11:44
I don't know why, but it's always the same:
WRITE down your problem and the answer is obvious.
Solved the problem by my own with a CA of type 102 (38 + 64: run VBScript text, synchronous execution with ignore exitcode) and the following VBScript Code in the Target column:
If Session.Mode(6)=True Then Session.Property("RebootAtEnd")="1" End If
The "6" means "msiRunModeRebootAtEnd".
After running this CA with a ControlEvent in the SetupCompleteSuccess dialog I can use the property "RebootAtEnd" to detect the required reboot.
h.teichert-ott
