We have two products - a beginner version and a full-featured version. The files in both versions all have exactly the same names, but one of the files is different internally, which gives the different versions.
The problem is, if a user installs the full-featured version on top of the beginner version, InstallShield thinks the files are the same, and thus doesn't actually install the full-featured version.
How can I distinguish these two identically-named files (one full-featured version, the other beginner version) and then convince InstallShield DevStudio 9 that if the user installs the full-featured on top of the beginner, to go ahead and upgrade the file?
Chris
Upgraded product, same file name?
cscooper
, May 01 2008 17:59
Posted 07 May 2008 - 16:28
Wth function GetFileInfo you can get the file size or the MD5 check sum. This should enable you to tell the files apart. Then you could delete/rename the existing file to let the new file install, or set the component to "always overwrite" or overwrite same or older version.
