In my Basic project I want to acheive the same thing as in the Standard project for the ReadyToInstall dialog. I want to display all the settings the user has chosen. I have tried using an Edit Field but you can't have line breaks. I tried using a scrollable text field but it doesn't seem that you can use a file that is created "on the fly" meaning that I tried creating a text file on the user's machine and have the scrollable text field point to that file.
Does anyone know how I can do this?
Jennifer
Display User's selection before copy
jmorgret
, Sep 12 2002 00:07
Posted 12 September 2002 - 07:18
Did you try a static text field? This should be able to use line breaks.
Posted 19 May 2004 - 16:33
You can't do that directly in the control properties in the dialog editor. Instead click the ... button to the right of your text. this will bring up the string table editor. Edit the string, using CTRL+ENTER to insert a line break.
