Installing and UnInstalling
Alamelu
Alamelu
  • Members
  • 11 posts
Posted 26 April 2005 - 16:31
Can you Install and Uninstall only a particular component from a feature?
If yes how can you do that in InstallScript MSI project and in merge module? While i am running the setup.exe , it should go read registry datas and according to the data in the registry the setup should install only one component, while uninstalling it should remove only that component.
It will be of great help if somebody could answer for this question.
Alamelu
Posted 27 April 2005 - 07:19
You could use a component condition but in general I'd suggest you use a feature for this. This could be an invisible sub-feature.
