I was trying to achieve the enable/disable functionality using the following code snippet:
#define CheckBox1 11
#define CheckBox2 12
#define Virtualization 12000 here Virtualization is the name of my dialog
#include "ifx.h"
export prototype EnableControls(HWND);
function EnableControls (hMSI)
HWND hwndDlg;
NUMBER nCmdValue, nResult;
STRING szDialogName;
begin
szDialogName = "Virtualization";
nResult = EzDefineDialog (szDialogName, "", "" ,Virtualization);
if (nResult < 0) then
MessageBox ("Error in defining dialog", SEVERE);
abort;
endif;
nCmdValue = WaitOnDialog(szDialogName);
switch (nCmdValue)
case DLG_INIT:
hwndDlg = CmdGetHwndDlg (szDialogName);
_WinSubEnableControl(hwndDlg, CheckBox2, 1);
endswitch;
end;
On virtualization dialog I have used the EnableControl function as DoAction for checkbox in which I want the other two checkboxes should enable. Also, condition set for checkbox is 1.
However, when I use the above code snippet I get the following error “Installshield cannot call DLL function: ISWindow” I tried to debug the code using the debugging feature in installshield and found that script is not able to recognize the dialog. Am I missing something?
aditya1685
, Sep 06 2011 12:52
