has anyone seen problems using writeprofstring on windows 9x?
i'm trying to do something like this:
[Title]
Key1=Value1
Key2=Value2
but i keep getting this instead only on windows 9x:
[Title]
Key1=Value1
[Title]
Key2=Value2
can anyone shed some light?
thanks.
WriteProfString on Windows 9x
BigEHead
, Dec 18 2002 22:44
Posted 19 December 2002 - 00:45
I don't make setups for Win9x/Me, so no idea, but you could always use WriteLine if you have to make it work right.
Posted 19 December 2002 - 17:24
I develop and test install scripts using Win 98se. I have not seen the behavior you mention (the section being duplicated). InstallShield suggests that you clear the cache by calling WriteProfString with null parameters. I do this after each entry to the .ini file.
// forces writing of file NOW
WriteProfString ( "","","","");
Posted 19 December 2002 - 18:44
i've already tried that and it doesn't help. so you've never seen that? i don't know why it happens. i've tried it on win95 and win98 and the same result. works fine on nt or 2k though. ugh....any other suggestions?
Posted 19 December 2002 - 23:38
Okay, well something to check then is whether you guys using the same version of IS.
Posted 22 December 2002 - 17:49
I believe that InstallShield internally calls Windows API functions for INI files. As far as I know these prevent dupilcate [section] entries. Therefore my suspicion is that there is some spelling difference in the two Title strings (maybe a blank or some non-printable character). Take a close look at the INI file with a text/hex editor.
