I have a custom dialog with a list box I am calling, and the first item in the list is always selected by default. I know that there is a was to select the default entry, but I would prefer to leave the list blank so that the user is forced to make a selection instead of just going with the default.
Can anyone think of a way to accomplish this?
Start with no items selected in list box
badejo
, Mar 14 2002 17:10
Posted 16 March 2002 - 09:51
Standard or Basic MSI project?
Posted 18 March 2002 - 22:28
It is a Standard project.
The INIT portion of my script is as follows"
case DLG_INIT: // This case will be called initially and should be used to
// initialize any controls in the dialog.
// Initialize the title of the dialog.
if ( szTitle != "" ) then
CtrlSetText( DLG_NAME, TITLE_FIELD, szTitle );
endif;
// Initialize the description field of the dialog.
if ( szDescription != "" ) then
CtrlSetText( DLG_NAME, DESCRIPTION_FIELD, szDescription );
endif;
nListResult = (CtrlSetList (DLG_NAME, 1302, nList1));
if (nListResult = 0) then
//MessageBox ( "list set successfully", INFORMATION);
else
MessageBox ( "CtrlSetList failed. Installation will abort.", INFORMATION);
abort;
endif;
endif;
endif;
else
abort;
endif;
Posted 18 March 2002 - 23:09
Moved to Developer - Standard Projects
