Hi ,
In my insall script and Custom Acions use property"SourceDir". "SourceDir" is determined by ResolveSource Aciton.But "ResolveSource" is only in UI sequence. I know the UI events don't get executed in a silent install. Can I add "ResolveSource" to the Execute sequence? If not,what can I do to let SourceDir be avaiable?
"ResolveSource" in silent install
nicole
, Mar 20 2006 09:37
Posted 20 March 2006 - 09:42
Sorry for missing something. I want to use silent install in command line .
Posted 20 March 2006 - 21:53
I have done this before and did not experience any problems doing it. As specified in the SDK the ResolveSource action has to come after the CostInitialize action.
Posted 20 March 2006 - 22:47
Glytzhof is correct, I do this in my installer as well.
I also have the condition "NOT REMOVE" on the action so it does not run for uninstalls.
Posted 22 March 2006 - 10:49
Thanks for Glytzhkof and luke_s.
I have another solution.To add this sourcedir into INI one file.And use Function GetProfString before I use "soucedir".It can work normally.I don't know it is the correct solution.
Posted 22 March 2006 - 10:51
And in silent install , UI sequence will not run. But in Execute install there is no "resolvesource".
I am a learner .Perhaps the questions is naive.
