I have a Basic MSI project which is replacing several individual older MSI projects. Everything is working well the new MSI project uses new Product, Upgrade and Package codes.
It would be nice to clean up the messy older entries in the control panel add remove programs.
In order to do this I added some registry entries in Local Machine,Software,Microsoft, Windows, CurrentVersion, Uninstall and set these to Uninstall Entire Key
I found that since these older programs were all installed with installshield basic MSI's I also had to remove entries from
HKEY Classes Root, Installer, Products and set these registry keys to Uninstall Entire Key
Problem is
It doesnt work
I wrote a stand alone program to remove these keys using INNO and this does the trick after the fact but I'd like the clean up to be part of the Installshield project so its more seamless and not a complicated chain of installation steps made from different products
So my question is
What needs to be done to have the Uninstall Entire Key Functionality work in Installshield 2010
