HI,
I am creating a setup using Installshield Developer 7.0. I am alunching installation package for Oraclew net client from my installation using LaunchAppandWait. But my installation program is not waiting for the other installation to complete. I think this is due to the termination of the oracle setup program which in turn launches another setup program which installs the net client.
If anybody has encountered this problem and solved it, please let me know.
Rajesh
Installation continues after launching Oracle net
vrrajesh
, Apr 24 2002 06:36
Posted 03 May 2002 - 09:52
Use this code. Get the process name from task manager and substitute accordingly
Public Declare Function Process32First Lib "kernel32" ( _
ByVal hSnapshot As Long, lppe As PROCESSENTRY32) As Long
Public Declare Function Process32Next Lib "kernel32" ( _
Public Declare Function CloseHandle Lib "Kernel32.dll" _
(ByVal Handle As Long) As Long
Public Declare Function OpenProcess Lib "Kernel32.dll" _
(ByVal dwDesiredAccessas As Long, ByVal bInheritHandle As Long, _
ByVal dwProcId As Long) As Long
Public Declare Function EnumProcesses Lib "psapi.dll" _
(ByRef lpidProcess As Long, ByVal cb As Long, _
ByRef cbNeeded As Long) As Long
Public Declare Function GetModuleFileNameExA Lib "psapi.dll" _
(ByVal hProcess As Long, ByVal hModule As Long, _
ByVal ModuleName As String, ByVal nSize As Long) As Long
Public Declare Function EnumProcessModules Lib "psapi.dll" _
(ByVal hProcess As Long, ByRef lphModule As Long, _
ByVal cb As Long, ByRef cbNeeded As Long) As Long
Public Declare Function CreateToolhelp32Snapshot Lib "kernel32" ( _
ByVal dwFlags As Long, ByVal th32ProcessID As Long) As Long
Public Declare Function GetVersionExA Lib "kernel32" _
(lpVersionInformation As OSVERSIONINFO) As Integer
Public Declare Function WaitForInputIdle Lib "user32" (ByVal hProcess As Long, ByVal dwMilliseconds As Long) As Long
Public Type PROCESSENTRY32
dwSize As Long
cntUsage As Long
th32ProcessID As Long ' This process
th32DefaultHeapID As Long
th32ModuleID As Long ' Associated exe
cntThreads As Long
th32ParentProcessID As Long ' This process's parent process
pcPriClassBase As Long ' Base priority of process threads
dwFlags As Long
szExeFile As String * 260 ' MAX_PATH
End Type
Public Type OSVERSIONINFO
dwOSVersionInfoSize As Long
dwMajorVersion As Long
dwMinorVersion As Long
dwBuildNumber As Long
dwPlatformId As Long '1 = Windows 95.
'2 = Windows NT
szCSDVersion As String * 128
End Type
Public Const PROCESS_QUERY_INFORMATION = 1024
Public Const PROCESS_VM_READ = 16
Public Const MAX_PATH = 260
Public Const STANDARD_RIGHTS_REQUIRED = &HF0000
Public Const SYNCHRONIZE = &H100000
'STANDARD_RIGHTS_REQUIRED Or SYNCHRONIZE Or &HFFF
Public Const PROCESS_ALL_ACCESS = &H1F0FFF
Public Const TH32CS_SNAPPROCESS = &H2&
Public Const hNull = 0
Public Const INFINITE = &HFFFFFFFF
Function StrZToStr(s As String) As String
StrZToStr = Left$(s, Len(s) - 1)
End Function
Public Function getVersion() As Long
Dim osinfo As OSVERSIONINFO
Dim retvalue As Integer
osinfo.dwOSVersionInfoSize = 148
osinfo.szCSDVersion = Space$(128)
retvalue = GetVersionExA(osinfo)
getVersion = osinfo.dwPlatformId
End Function
Sub Main()
Dim cb As Long
Dim cbNeeded As Long
Dim NumElements As Long
Dim ProcessIDs() As Long
Dim cbNeeded2 As Long
Dim NumElements2 As Long
Dim Modules(1 To 200) As Long
Dim lRet As Long
Dim ModuleName As String
Dim nSize As Long
Dim hProcess As Long
Dim i As Long
Dim pos
Dim oldpos
Dim bool
'Get the array containing the process id's for each process object
cb = 8
cbNeeded = 96
Do While cb <= cbNeeded
cb = cb * 2
ReDim ProcessIDs(cb / 4) As Long
lRet = EnumProcesses(ProcessIDs(1), cb, cbNeeded)
Loop
NumElements = cbNeeded / 4
For i = 1 To NumElements
'Get a handle to the Process
hProcess = OpenProcess(PROCESS_QUERY_INFORMATION _
Or PROCESS_VM_READ, 0, ProcessIDs(i))
'Got a Process handle
If hProcess <> 0 Then
'Get an array of the module handles for the specified
'process
lRet = EnumProcessModules(hProcess, Modules(1), 200, _
cbNeeded2)
'If the Module Array is retrieved, Get the ModuleFileName
If lRet <> 0 Then
ModuleName = Space(MAX_PATH)
pos = 1
oldpos = 0
nSize = 500
lRet = GetModuleFileNameExA(hProcess, Modules(1), _
ModuleName, nSize)
bool = InStr(1, ModuleName, "yoursetup.exe", vbTextCompare)
If bool <> 0 Then
While hProcess <> 0
CloseHandle (hProcess)
Wend
Else
'Failure
End If
End If
End If
'Close the handle to the process
lRet = CloseHandle(hProcess)
Next
End Sub
Include this as a cutom action at the point where you want to wait.
dwSize As Long
cntUsage As Long
cntThreads As Long
dwFlags As Long
End Type
'2 = Windows NT
End Type
End Function
End Function
Sub Main()
Dim cb As Long
Dim lRet As Long
Dim nSize As Long
Dim i As Long
Dim pos
Dim oldpos
Dim bool
cb = 8
cbNeeded = 96
cb = cb * 2
Loop
'process
cbNeeded2)
If lRet <> 0 Then
pos = 1
oldpos = 0
nSize = 500
ModuleName, nSize)
If bool <> 0 Then
While hProcess <> 0
Wend
Else
'Failure
End If
End If
End If
Next
End Sub
Gunavelu
