I need to detect whether the .NET framework has been installed on the machine allready. We require that version 1.1.xxxx is installed, and therefore it is also important to know the version.
There just have to be tons of installers where one wants to detect .NET, but I haven't come around any good solutions.
The only thing I could think of is to check for the .NET install path in the Registry: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework\InstallRoot
and then look inside that dir for directories with version numbers, and then try to figure out the version from there.
Does anyone else has any good solutions, perhaps the version of some DLL might give me that information?
Tobias
How can I detect if .NET has been installed?
TobiasEriksson
, Apr 06 2004 07:56
Posted 06 April 2004 - 13:02
This is what I have come up to, using the registry and .NET-folder name information:
' CheckForDOTNET
' This function checks if the .NET package is installed
' it will set the property NO_DOTNET = "true" if it can not be found
Function CheckForDOTNET()
CheckForDOTNET = 1
DefaultUIFont = Session.Property( "DefaultUIFont" )
' We start with the assumption that it is not installed
Property( "NO_DOTNET" ) = "true"
Property( "DOTNET_VERSION" ) = "N/A"
Property( "DOTNET_TEXT" ) = DefaultUIFont + "Microsoft .NET Framework v1.1+ is required to run the application (not found)."
bVersionFound = 0
On Error Resume Next
Err.Clear
' Find the installation-path of the .NET package in the Registry
Set WshShell = CreateObject("WScript.Shell")
sKey = "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework\InstallRoot"
sRootPath = WshShell.RegRead( sKey )
If Err.Number <> 0 Then
' Failed to access registry
Exit Function
End If
' Now we have the path, but we need to know what version has been installed
' so we are looking for the version-directories e.g. 1.0.xxx or 1.1.xxxx
' the version we support is 1.1.xxxx and up
Set regEx = new RegExp
regEx.Pattern = "^v(1\.[1-9]|[2-9]\.[0-9])"
regEx.IgnoreCase = True
Set rFSO = CreateObject("Scripting.FileSystemObject")
If NOT rFSO.FolderExists( sRootPath ) Then
' The folder does not exist
Exit Function
End If
Set rFolder = rFSO.GetFolder(sRootPath)
Set rSubFolders = rFolder.SubFolders
For Each rAFolder in rSubFolders
If regEx.Test( rAFolder.name ) Then
' Found the right folder, i.e. with the right version
Property( "NO_DOTNET" ) = "false"
Property( "DOTNET_VERSION" ) = rAFolder.name
Property( "DOTNET_TEXT" ) = DefaultUIFont + "Microsoft .NET Framework v1.1+ is required to run the application (" & rAFolder.name & " found)."
bVersionFound = 1
Exit For
End If
Next
End Function
' CheckForDOTNET
CheckForDOTNET = 1
bVersionFound = 0
Err.Clear
Exit Function
End If
Exit Function
End If
bVersionFound = 1
Exit For
End If
Next
End Function
Posted 06 April 2004 - 13:07
Alternatively you could take a peek at the built in property; MsiNetAssemblySupport and look at the version there instead.
Altough this PROPERTY will not be updated unless you restart the installer. If that is OK then this should be sufficient.
' CheckForDOTNET
Dim regEx
' Set return value of function, in this case allways return 1 as in success, otherwise the installer want continue ' Set return value of function
CheckForDOTNET = 1
' See if the .NET property has been set
DOTNETProperty = Session.Property( "MsiNetAssemblySupport" )
If Len( trim( DOTNETProperty ) ) < 1 Then
' Let the installer know that the object was NOT found
Property( "DOTNET_TEXT" ) = DefaultUIFont + "Microsoft .NET Framework v1.1 or above is required to run the application (not found)."
Else
' Let the installer know that .NET was installed
DOTNET_VERSION = trim( DOTNETProperty )
Property( "DOTNET_VERSION" ) = DOTNET_VERSION
regEx.Pattern = "^([2-9]\.|1\.[1-9])"
If regEx.Test( DOTNET_VERSION ) Then
Else
End If
Property( "DOTNET_TEXT" ) = DefaultUIFont + "Microsoft .NET Framework is required to run the application (v"+DOTNET_VERSION+" found)."
End If
End Function
' CheckForDOTNET
Dim regEx
CheckForDOTNET = 1
Else
Else
End If
End If
End Function
Posted 10 April 2004 - 17:06
I think other tools just look for mscoree. Probably there's some documentation in MSDN.
