Question: What do I have to do in an install project that will update the correct information in order to have a file extension (.xyz for example) have the "Open with" display "XYZ Utility" as its menu option.
FYI: I am running version 6.22 if it matters. Also, I am able to correctly associate the file extension with the correct applicate exe so that when I double click on a file, it opens using the correct application. But, I am stumped on the "Open with" submenu. The "Open with" currently does not have a submenu and when I click on the "Open with" option, it brings up list of all applications like it is does not currently have a file extension association.
Any help or ideas would be greatly appreciated. Thanking you in advance.
