Change or Rmove Program in Vista x64 problem
danielxu22
, Oct 20 2005 03:28
Posted 20 October 2005 - 03:28
I use WinXP AMD64 installation package tested under Vista x64 OS, after it Finished, I could not find any item about my installation in the Change or Remove Program.
I create a new one, and the same thing happened.
I use InstallShield 10.5 Premier Edition. Set value "AMD64;1033" in the place of "General Information" --> "Summary Information Stream" --> "Template Summary". Compiled source under WinXP SP2.
Does anyone know about this? Thanks!
BR,
Daniel
BR,
Daniel
Posted 20 October 2005 - 20:36
A verbose log may help diagnosing the problem.
Posted 21 October 2005 - 08:36
| QUOTE (Stefan Krueger @ 2005-10-20 20:36) |
| A verbose log may help diagnosing the problem. |
Hi, Stefan,
Thanks for your reply.
"A verbose log"? What is it?
Dose it a utility of Vista OS? I don't know.
Needs your help. Thanks again.
BR,
Daniel
Posted 23 October 2005 - 15:08
Posted 31 October 2005 - 04:14
| QUOTE (Stefan Krueger @ 2005-10-23 15:08) |
| Please see here: How do I create a log file of my installation? http://www.msifaq.com/a/1022.htm |
Hi, Stefan,
I followed the document of "How do I create a log file of my installation", and create a log file under Vista x64 OS. (Attached file)
But I could not find any useful information. ARPSYSTEMCOMPONENT sets 1.
BTW, I install the InstallShield 10.5 Premier Edition in the Vista x64 computer, still can not find any item in the Add or Remove Program List.
BR,
Daniel
Posted 31 October 2005 - 12:22
| ARPSYSTEMCOMPONENT sets 1. |
From the MSiIdocumentation:
| Setting the ARPSYSTEMCOMPONENT property to 1 using the command line or a transform prevents the application from being displayed in the Add or Remove Programs list of Control Panel. |
So unless I'm misunderstanding your question, it's working exactly as intended.
Posted 01 November 2005 - 03:08
| QUOTE (Stefan Krueger @ 2005-10-31 12:22) | ||||
So unless I'm misunderstanding your question, it's working exactly as intended. |
Hi, Stefan,
No, I am not use command line set ARPSYSTEMCOMPONENT as 1. I just open the log file and find something about ARPSYSTEMCOMPONENT. The following lines show the word of ARPSYSTEMCOMPONENT.
TARGETDIR=D:\ USERNAME="Windows User" USERPROFILE=C:\Users\Administrator\ ARPSYSTEMCOMPONENT=1 ARPNOMODIFY=1 ARPNOREMOVE=1 ISSETUPDRIVEN=1
MSI (s) (1C:B4) [09:55:45:250]: PROPERTY CHANGE: Adding ARPSYSTEMCOMPONENT property. Its value is '1'.
Property(S): ARPSYSTEMCOMPONENT = 1
ISALWAYSINSTALLELEVATED;ISSETUPDRIVEN;ARPSYSTEMCOMPONENT;ARPNOMODIFY;ARPNOREMOVE;INSTALLDIR
So I said "ARPSYSTEMCOMPONENT sets 1". I'm not sure about this value. The same setup program installed under WinXP AMD64 & Vista AMD64, it will have different result. Under WinXP AMD64, it was successful, but under Vista AMD64, I could not find my installation in the ARP. Even I installed IS 10.5 software under Vista x64, it does not show any infomation about InstallShield 10.5 in the ARP List.
Maybe the Vista is a beta version. But our custom wants the program under Vista.
BR,
Daniel
Posted 02 November 2005 - 11:15
Someone or something sets the ARPSYSTEMCOMPONENT property to 1. As a result the program is not listed in ARP. The latter is expected behaviour. So the real question is: who is setting ARPSYSTEMCOMPONENT=1. I have no idea.
