I need to add a registry entry for a file that exists in the TARGETDIR (Application Folder). That is , I have a file called foo.txt that will be installed in my Application Directory, for example c:\myinstalldir\foo.txt and I need to create a registry entry that uses this path and file as the value. The problem is that it can't be hardcoded because it needs to match whatever the install directory is. Is this possible?
using TARGETDIR in registry key
lacto
, Mar 05 2003 23:29
