How to install COM+ components in ISWI? Thanks for any suggestion.
COM+ Components
Zhouli
, Aug 27 2001 07:21
Posted 28 August 2001 - 08:44
There is the COMPlus table, which is part of the windows installer. I haven't had a large amount of success with that one, so I've been creating my COM+ applications using a VBScript based custom action.
Within my Custom Action, I make use of the COMAdminCatalog object, from that I can create applications, add components, delete stuff, set properties, etc.
Posted 28 August 2001 - 15:50
I have just exported the applications from the Component Services control panel, and then setting up nested installs from my main install. I also have some VBScript CA's that modifiy some of the settings on the applications after the fact.
Posted 28 August 2001 - 20:15
Does you nested msi method work if you perform a Repair install (reinstall) of the main package?
Posted 29 August 2001 - 10:05
Hi Zhouli
Which version of ISWI do u use?? pl. let me know as even I need the support of MTS / COM+.
Sankar
