Log file question
spdygnlz
, Nov 28 2006 19:40
6 replies to this topic
Posted 28 November 2006 - 19:40
I love the log file feature in the MSI projects and the included viewer is great. My problem is that there are 3 sections that never get any information: Feature States, Component States, and File Actions. These would be really helpful, but I can't figure out how to get that information in the log. I've looked around for information to enable these, but I think part of my problem is I don't know quite what to look for. Can anyone help? Thanks!
-- spdygnlz --
Posted 29 November 2006 - 14:09
Did your install complete successfully? If not it may not have run to the point where it writes feature state to the log.
Posted 29 November 2006 - 17:31
Yes, they always finish correctly. It always finishes with a value of "0". Could there be something I'm missing in the command line? This is what I'm using:
/l*v "C:\Installation.log"
-- spdygnlz --
Posted 30 November 2006 - 18:48
That's looking good. If you open the log file with a text eidtor do you see deature states? And which version of MSI runtime are you using, and which version InstallShield?
Posted 30 November 2006 - 20:00
Yes, I do see that info in there:
| MSI (s) (A8:58) [16:16:23:519]: Feature: TestDM; Installed: Absent; Request: Local; Action: Local MSI (s) (A8:58) [16:16:23:519]: Feature: WebDisplay; Installed: Absent; Request: Local; Action: Local MSI (s) (A8:58) [16:16:23:519]: Component: GenericObject.ocx; Installed: Absent; Request: Local; Action: Local MSI (s) (A8:58) [16:16:23:519]: Component: RodPositionMonitor.ocx; Installed: Absent; Request: Local; Action: Local . . . InstallFiles: C:\Program Files\My Company\MyProject\RodPositionMonitor.ocx SIZE: 450560 bytes MSI (s) (A8:58) [16:16:42:995]: Note: 1: 2318 2: C:\Program Files\My Company\MyProject\RodPositionMonitor.ocx MSI (s) (A8:58) [16:16:43:026]: Executing op: FileCopy(SourceName=PROJDS~1.DLL|projDSManager.dll,SourceCabKey=projdsmanager.dll,DestName=projDSManager.dll,Attributes=8192,FileSize=684032,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=6.12.0.0,Language=1033,InstallMode=58982400,,,,,,,) MSI (s) (A8:58) [16:16:43:026]: File: C:\Program Files\My Company\MyProject\projDSManager.dll; To be installed; Won't patch; No existing file MSI (s) (A8:58) [16:16:43:026]: Source for file 'projDSManager.dll' is uncompressed, at 'C:\Documents and Settings\username\Desktop\DISK1\program files\My Company\MyProject\'. |
I'm using the Windows Installer 3.1 and InstallShield Premier 12.
So, I don't know how clearly I stated my problem before... I don't see the information in the MSI Log Analyzer. I suppose I could use the straight text file if I had to, but the thing is about 30MB. Not looking forward to reading that monster in notepad.
Could it be a problem with the extension? The log viewer by default wants a .wil file. Should I be making the .log a .wil instead or is that something different?
Edited by spdygnlz, 30 November 2006 - 20:06.
-- spdygnlz --
Posted 30 November 2006 - 23:14
Looks like the log viewer doesn't understand the MSI 3 log file format, maybe because of the time stamps. It works proeprly with MSI 2 logs.
Posted 30 November 2006 - 23:31
Ah. Bummer. Thanks for looking into it. I think I might ask Installshield about their plans to fix it.
-- spdygnlz --
