can anyone help
can i put a splash .bmp file up when setup.ese is clicked on
Posted 24 February 2001 - 00:06
Posted 02 March 2001 - 17:41
Posted 15 March 2001 - 23:37
If you are running a setup.exe wrapper, you can deploy a form (e.g. a VB form) that simply sits there until you close the program. If you don't display the form as VBModal or VBSystemModal, it will remain in the background. Then you can keep the wrapper running until the MSI package completes.
If you want to put the display into the MSI package, then you can create a Dialog with whatever controls you want to have on it ... typically a bitmap and some text ... size it appropriately, and initiate the display as the first thing in your InstallExecuteSequence. Then add the decimal value 16 to the attributes of all your other dialogs (the setting keeps non-modal dialogs) so that they don't destroy the background.
There are some display challenges with the latter method that I have not completely worked out, but that will give you a starting point.
My method of doing this, by the way, is through direct manipulation of the MSI Dialog and Control tables. I don't know how this works out with one of the third party packagers.
