The install folder for my application depends on the location of another app (Apache Tomcat); it's installed in a subfolder of Tomcat.
In 'System Search', I look for the path of Tomcat in the registry, then store it in a variable (APACHELOCATION).
My problem comes when I want to use this variable to define the install directory for my app:
I tried modifying [INSTALLDIR] in the 'Product Properties' by using the [APACHELOCATION] variable, but that doesn't seem to work. How do I use this variable to create my install folder path (like so: [APACHELOCATION]\Webapps\Test)
Am I even on the right track here?
Confused...
Thanks for any help you can give me.
Using variable in installdir
KKop
, Aug 03 2007 14:29
Posted 07 August 2007 - 14:45
Add a custom action type 51 (set a property) that sets INSTALLDIR to [APACHELOCATION] with a condition of APACHELOCATION (so that it only runs if APACHELOCATION was found). Insert it in the Install UI and Execute sequences, before CostInitialize.
