I’ coming with a “problem” I don’t know actually if there is a problem or a limitation of InstallShield. In *.msm file, I want to conditioning the component with one property which is setup in the main project, where the *.msm file was important (added).
Right now, the binaries from the merge module get installed even if the property is true or not.
Is this scenario working, if the property is set in the main project, in InstallShield script, and than, based on the value, conditioning a component to get installed, in the msm file?
Later edit:
I'm using InstallShield X, Basic MSI project type.
Sebastian.
Edited by sebica79, 22 June 2006 - 10:04.
