Hello,
I've run into an issue and I need some outside perspective. My services install and uninstall fine when the user installs to the default path of Program Files\App, but if they select something outside of PF, say C:\Temp, the files and services install fine, but they fail to uninstall. I think it has to do with the folder I have set to INSTALLDIR, that the install does not know where to look during the uninstallation. (Though the user-defined value for INSTALLDIR is set in the script.)
Can someone out there please suggest a solution? Thanks for any suggestions, because I am at a loss.
Services fail to uninstall
Mariscal
, Jul 30 2008 23:11
Posted 05 August 2008 - 17:23
In case it's of use to anyone, the workaround to this is to create a registry key called [INSTALLDIR] under HKLM\Software\CompanyName\ProductName, and then add a System Search for this registry key for when the installation is in maintenance mode. After a clean install, you can see the install path stored in the aforementioned registry location; the key is removed during a Remove.
