Hello,
I have a Basic MSI Project created with InstallShield 11.
Now we upgraded to InstallShield2010.
We always used the following line to read a Msi property in our InstllScript:
MsiGetProperty not working in InstallShield2010
kretmatt
, Aug 19 2010 08:25
Posted 19 August 2010 - 08:25
CODE |
nValueBuf = 3; MsiGetProperty(ISMSI_HANDLE,"ProductName", svProductName, nValueBuf); |
Now in InstallShield2010 the function MsiGetProperty returns ERROR_MORE_DATA.
We changed the line to this to avoid this error:
CODE |
nValueBuf = MAX_STRING; nvReturn = MsiGetProperty(ISMSI_HANDLE,"ProductName", svProductName, nValueBuf); |
The problem is that the variable svProductName is still empty, after the function call.
Furthermore the help says:
QUOTE |
ISMSI_HANDLE is not supported in Basic MSI projects, and is not supported in InstallScript custom actions. |
But this was also in the help of InstallShield11 and it worked perfectly till the upgrade to 2010.
Could somebody give me a hint!
Please!
Thank you in advance.
Regards,
Matthias
Posted 19 August 2010 - 08:48
UPDATE:
I found out that it is working when I set the Custom Action to "Immediate Execution" instead of "Deferred Execution".
But this is not what I want. I need to execute the funktion after all files are installed --> Deferred Execution After InstallFiles.
