Open IS 6 project in IS 7?
schoeneichebb
, Sep 19 2002 12:08
6 replies to this topic
Posted 19 September 2002 - 12:08
Can an InstallShield Professional 6.1 project be opened in
InstallShield 7 without manual modifications?
Is it compatible?
Are necessary alterations automatically made?
Thank you for your help.
Frank Lehmann
Is it compatible?
Frank Lehmann
Posted 20 September 2002 - 07:12
It should automatically be converted. However I thnk the migration guarantee is only valid for 6.3 projects.
Posted 20 September 2002 - 07:32
I have to correct myself. What I said is true for InstallShield Professional 7.
IS 6 projects can be imported to Developer 7, but some manual work will be required in most cases. I believe there's a migration white paper at installshield.com
Posted 23 September 2002 - 07:48
Hello Stefan,
Thanks for your help.
I've found additional information at
http://www.installsh...o/migration.asp
Frank Lehmann
Frank Lehmann
Posted 23 September 2002 - 13:55
That document is about Professional 7. If you are using Developer 7 it doesn't apply.
BTW if you're using Professional then this is the wrong group.
Posted 01 October 2002 - 07:57
Hello Stefan,
I seem not to be aware of the difference between InstallShield 7 Professional and Developer.
So far I've thought that Developer is Professional
plus Windows Installer but that's obviously not
the case (total confusion). So I'll pay more attention
to the correct newsgroup in future.
My IS 6 project is for a client who has still to
decide whether he will purchase IS 7 Prof or Dev
for himself to be able to revise this project later on.
Frank Lehmann
Frank Lehmann
Posted 01 October 2002 - 09:29
Developer and Professional both use InstallScript (although it's optional in Developer), but under the hood they use very different technology.
