I have 3 different setup types in my installer. There is some chnages to the dialog boxes displayed based on the setup types. I am using SdsetuptypeEx function during recording the setup. The problem is while recording the input is read from the input file properly, during playback although the playback values seems to be fine, the components that are installed are from the last setup type that is displayed in the "setup" component pane. Any idea how to solve this problem ?
1. should I record the installer for different setup types - each time, I change the installer
2. Is there any other alternative to this ?
Any help is appreciated
silent installs - different setup types
ramaswamy
, Sep 12 2002 18:29
Posted 12 September 2002 - 20:42
Wow, I had a hard time understanding what you were trying to say here, but I think I got it.
Now I only messed around with SdSetupTypeEx for a little while before moving to AskOptions, but I think even with the former you need to make a call to ComponentSetupTypeSet. Try this and re-run your setup as if it's a fresh install.
