HOW do I Add a custom path to INSTALLDIR during setup
carlod
, Jun 29 2001 21:35
Posted 29 June 2001 - 21:35
I created a setup program that copies asp scripts and creates a virtual directory on iis5. My default INSTALLDIR is c:\program files\appserver however during the install I have a custom dialog boxes that asks the user for a database name. I want this database to be add to the INSTALLDIR so that it becomes c:\program files\appserver\database_name. This becomes the new target? Also, is there a way to install multiple copies of the same install? If so, can the product name under add/remove programs be modified dynamically?
Posted 11 July 2001 - 15:49
This is covered quite well in the Developers Guide.
Basicly you want a type 51 CA (Set a directory) to set INSTALLDIR to your value.
As for the second part, I don't think so. Co-residency or side-by-side installations require different Product Codes
