How to disable some objects of a custom dialog
kgiloo
, Oct 19 2006 10:15
6 replies to this topic
Posted 19 October 2006 - 10:15
[BASIC MSI]
Lets assume that I have a radiobutton group (property RADIOPROP) with 2 radio buttons and some other edit boxes, static texts etc...
Depending on the clicked radio button I want to enable/disable the other objects of the custom dialog.
Posted 19 October 2006 - 15:54
I was wrongly looking in the dialog behavior editor.
This things take place in the direct editor.
Additional Tools - Direct Editor - ControlCondition
MyDialog / EditBox / Disable / RADIOPROP=1
MyDialog / EditBox / Enable / RADIOPROP=2
Posted 20 October 2006 - 07:28
Dialog Editor > Dialog Behaviour > Conditions tab (the tabs are at the bottom edge)
Posted 23 October 2006 - 14:03
I did try from the Behavior Editor but couldn't manage to do it. Therefore I did it with the direct editor with success.
May I ask you some details?
Thx
Thx
Posted 23 October 2006 - 15:27
In the beaviour view, select the radio group, switch to the conditions tab and add an Enable condition and a Disable condition. How far did you get, which steps should I explain in more detail?
Posted 24 October 2006 - 16:07
OKAY.
I was only focused on the top.
I suppose there's nothing I should insert 'manually' through the direct editor?
This is a more general question.
Posted 24 October 2006 - 18:30
There are a few things that you can only do in the Direct Editor, but most of the time you don't really need it.
