I have an InstallScript MSI Project in which certain components are installed based on the value of a Property defined in the Property Manager.
ComponentA needs to be installed when MyProperty = "A", so the Condition for this component is set to:
MyProperty = "A"
ComponentB needs to be installed when MyProperty = "B", so the Condition for this component is set to:
MyProperty = "B"
The value of the property is not provided on the Property Manager screen. It is set during the setup process by MsiSetProperty(). The following code is used:
MsiSetProperty (ISMSI_HANDLE, "MyProperty", sText);
where sText = "A" or "B".
Within the InstallScript code, I tried using MsiGetProperty() to make sure that I am getting and setting the correct property. I used the following code:
nvSize = 256;
MsiGetProperty (ISMSI_HANDLE, "MyProperty", sText, nvSize);
MessageBox("The value is " + sText, INFORMATION);
If I call this before I set the property, the value shown is the same initial value set in the Property Manager screen. If I call it after I set the property, the value shown is the new value that I just set it to. This tells me that I am indeed getting and setting the correct property.
But my installation seems to ignore the changed value of the property. After installation is performed, it seems that ComponentA is only installed when MyProperty is set to "A" in the Property Manager. Likewise, ComponentB is only installed when MyProperty is set to "B" in the Property Manager.
It seems as if the installation is completely ignoring the value that is set in the InstallScript. What am I doing wrong?
Set Component Condition through Property
shahedC
, Nov 11 2004 23:57
