Hello,
is there a possibility to let the setup.exe use another ini file as setup.ini?
Rename of setup.exe to xyz.exe and want to use a xyz.ini.
Thanks in advance!
Johannes
P.S. Using IS2010 and newer
setup.exe and setup.ini
Johannes John
, Dec 21 2010 16:04
Posted 28 December 2010 - 11:06
I don't think that there's a way to configure this, the setup.ini name is most likely hard coded in setup.exe. So unless you want to binary hack the setup.exe I don't think you can do this.
Posted 07 January 2011 - 10:26
What about possibly creating and using a setup.ini file in a way that setup.exe normally reads it in other setup package products. I'm working with vs 2010 by the way, and am still studying the product.
The setup.exe I created with vs doesn't seem to read the setup.ini file I created.
I wonder if anybody knows about this issue?
[Edited to remove link]
Edited by Stefan Krueger, 07 January 2011 - 11:16.
