During the installing, a Custom Action was called. When this CA was called and processed, I wanted to dislay some information on the setupProgress Dialog.
For that, I defined a new entry in ActionText control. However, the description
didn't show up.
Anything else I need to do?
How to display install progress from CA
bluesky9898
, Jan 28 2004 19:59
8 replies to this topic
Posted 29 January 2004 - 08:26
This only works for deferred custom actions.
Posted 29 January 2004 - 10:14
If your CA is type 1 (DLL call), you can use MsiProcessMessage to control the text at runtime.
AFAIK, this method works for all kinds of CAs (normal, deferred, rollback) anywhere in the Execute sequence.
Posted 29 January 2004 - 19:35
I've tried the MsiProcessMessage on my basic msi project. The text is updated (immediate action, ui sequence), but the progress bar is not updated.
I launch some exe files during the ui sequence and really need to update the progress bar to inform the user that something's happening, but I don't know how to get this to work? I've read a thread on InstallShield Community (see below), which doesn't give me much hope to succeed in installscript/ui sequence, but I figure there has to be a solution to this??
Linda
__________________________
http://community.ins...threadid=123406
Actually, you'll need two actions: an immediate one to add the total number of ticks to the progress bar, and a deferred one to add individual ticks to increment the progress bar.
For a VBScript version of the general ideas, please see this thread: http://community.ins...threadid=105165.
Linda
Posted 30 January 2004 - 05:17
Try getting a hold of the Windows Installer SDK, this contains an example of how to update the progress bar.
Posted 31 January 2004 - 12:44
I've looked in the help for Windows Installer. The code I'm using is taken from "Adding Custom Actions to the progress bar", but I've modified it so it's InstallScript now.
The first part works (updating the text), but unfortunately nothing happens to the progress bar until my exe file has finished running (actually probably even later in the seqence).
Maybe I have to split it into several custom actions, one for updating the text, one to run the exe file and then a third one to update the ticks on the progress bar?
I'm also a little confused as to how the ActionText, SetProgress dialog and the progress bar control event work together. What do I have to "link together" (and how) to get this to work? It would be nice to be able to use a subscription in some way.
Regards,
Linda
Regards,
Linda
Posted 09 February 2004 - 17:54
Problem solved!
Now I can both display progress text and add ticks to the progress bar. All this is done as immediate execution CA's in the ui sequence.
Add total ticks to the progress bar and reset the progress bar - this CA is sequenced before SetupProgress.
Display progress text.
Run the CA that should affect the progress.
Add a CA that increments the progress bar.
The progress bar should subscribe to the CA incrementing the progress.
Include ISMsiQuery.h.
/Linda
function CA_Progress(hInstall) // increment the progress bar
NUMBER iResult;
HWND hRec, hProgressRec;
NUMBER nvBufferSize;
begin
hRec = MsiCreateRecord(3);
hProgressRec = MsiCreateRecord(3);
// Tell the installer to use explicit progress messages.
MsiRecordSetInteger(hRec, 1, 1);
MsiRecordSetInteger(hRec, 2, 1);
MsiRecordSetInteger(hRec, 3, 0);
iResult = MsiProcessMessage(hInstall, INSTALLMESSAGE_PROGRESS, hRec);
//Specify that an update of the progress bar's position in
//this case means to move it forward by one increment.
MsiRecordSetInteger(hProgressRec, 1, 2);
MsiRecordSetInteger(hProgressRec, 2, szSizeTickIncrement);
MsiRecordSetInteger(hProgressRec, 3, 0);
// The following tells the installer to send a message to update
// the progress bar.
iResult = MsiProcessMessage(hInstall, INSTALLMESSAGE_PROGRESS, hProgressRec);
MsiCloseHandle(hRec);
MsiCloseHandle(hProgressRec);
end;
/Linda
NUMBER iResult;
begin
end;
Posted 24 February 2010 - 13:00
Hi
I am new to Installshield. I am using Installshield 2010.
My problem is also similiar, i added a dialog in the UI sequence for the extracting of files, since it took a long time i am trying to add a progress bar. So i followed this particular thread.
sequenced the resetProgress CA before setupprogress dialog
sequenced the addProgress CA after the setup progress dialog
sequenced the IncrementProgress after addProgress CA
added message in the action text which is subscibed in the progressbar in setup progress dialog
all CA's are scheulded as immediate action in UI sequence
all CA's are subscribed to progressbar in the setup progress dialog
I used the code from msdn.microsoft.com/en-us/library/aa367525(VS.85).aspx and splitted it into three CA's. I cross checked the code available in the link with the code available in this thread.
But still progress is not visible in progressbar, but i can see the action text message.
could anybody help me on this?
Vignesh
Vignesh
Edited by vigneshraja123, 24 February 2010 - 13:11.
Posted 26 February 2010 - 12:23
Here is the comple code of setup.rul
// IIIIIII SSSSSS
// II SS InstallShield ®
// II SSSSSS © 1996-2002, InstallShield Software Corporation
// II SS All rights reserved.
// IIIIIII SSSSSS
// This template script provides the code necessary to build an entry-point
// function to be called in an InstallScript custom action.
// File Name: Setup.rul
// Description: InstallShield script
// Include Ifx.h for built-in InstallScript function prototypes, for Windows
// Installer API function prototypes and constants, and to declare code for
// the OnBegin and OnEnd events.
#include "ifx.h"
#include "ISMsiQuery.h"
// The keyword export identifies MyFunction() as an entry-point function.
// The argument it accepts must be a handle to the Installer database.
export prototype ResetProgressBar(HWND);
export prototype AddProgressBar(HWND);
export prototype IncrementProgressBar(HWND);
NUMBER iTickIncrement;
NUMBER iNumberItems;
NUMBER iTotalTicks;
// To Do: Declare global variables, define constants, and prototype user-
// defined and DLL functions here.
// To Do: Create a custom action for this entry-point function:
// 1. Right-click on "Custom Actions" in the Sequences/Actions view.
// 2. Select "Custom Action Wizard" from the context menu.
// 3. Proceed through the wizard and give the custom action a unique name.
// 4. Select "Run InstallScript code" for the custom action type, and in
// the next panel select "MyFunction" (or the new name of the entry-
// point function) for the source.
// 5. Click Next, accepting the default selections until the wizard
// creates the custom action.
// Once you have made a custom action, you must execute it in your setup by
// inserting it into a sequence or making it the result of a dialog's
// control event.
// Function: MyFunction
// Purpose: This function will be called by the script engine when
// Windows Installer executes your custom action (see the "To
// Do," above).
function ResetProgressBar(hMSI)
NUMBER iResult;
begin
iTickIncrement = 10000;
iNumberItems = 10;
iTotalTicks = iTickIncrement * iNumberItems;
hRec = MsiCreateRecord(4);
hProgressRec = MsiCreateRecord(4);
MsiRecordSetInteger(hProgressRec, 1, 0);
MsiRecordSetInteger(hProgressRec, 2, iTotalTicks);
MsiRecordSetInteger(hProgressRec, 4, 0);
iResult = MsiProcessMessage(hMSI, INSTALLMESSAGE_PROGRESS, hProgressRec);
end;
// Do," above).
function AddProgressBar(hMSI)
HWND hActionRec, hProgressRec;
NUMBER iResult;
NUMBER iCount;
begin
hProgressRec = MsiCreateRecord(2);
MsiRecordSetInteger(hProgressRec, 1, 3);
end;
// Do," above).
function IncrementProgressBar(hMSI)
NUMBER iResult;
begin
iResult = MsiProcessMessage(hMSI, INSTALLMESSAGE_PROGRESS, hRec);
MsiRecordSetInteger(hProgressRec, 2, iTickIncrement);
end;
I created 3 custom action
NmResetProgressBar
NmIncrementProgressBar
NmAddprogressBar
I sequenced as
NmResetProgressBar
SetupProgress Dialog
NmAddProgressBar
ISSetupFilesExtract.
The reason i am using a progress bar it is taking some time to extract the files which is added in the support files.
Could you help me on this?
Vignesh
// IIIIIII SSSSSS
// IIIIIII SSSSSS
#include "ifx.h"
NUMBER iTotalTicks;
// control event.
// Do," above).
NUMBER iResult;
begin
iNumberItems = 10;
end;
// Do," above).
NUMBER iResult;
NUMBER iCount;
begin
end;
// Do," above).
NUMBER iResult;
begin
end;
NmResetProgressBar
NmAddprogressBar
I sequenced as
NmResetProgressBar
NmAddProgressBar
Vignesh
